Day #3 progress....
Rebuilt decompressor w/ new cotter pin & copper seals. New cable and had to spin with valve grinding paste to make air tight. Very dirty for only 600 miles.
New fluids in all 3 places (Mercury 90 wt gear oil / 20-50 GTX Castrol / ATF-Ford 420 ml) New primary gasket.
New clutch cable & adjustment.
New petcock & refreshed fuel line & filter.
Rebuilt MikCarb VM28 w/ new main/needle jets. Reused primary. New enricher pull button type [not lever]
Had to reuse float valve because ordered wrong one [Mikuni VM28 does not fit...Wrong thread]. Then ordered one from India that was POS and unusable.
If it sticks again I'm gonna throw a spanner.
Where in the hell do you find a proper/functioning float valve?
Intake manifold is lost in the mail somewhere between my house and country I can't pronounce.
Got tires [Dunlap K70's 3.5" & 3.25"] in the mail today along w/ tubes & rim strip.
1/8" fuel vent hose apparently delivered to wrong house
BTW...I only have 2 drain plugs on dad's and BOTH have screens. I thought there were 3 and the rear one did not have a screen???
Went for a little dive into the spaghetti behind the headlight & got all the flashers blinking & tail lights working. Horn inop...Add to list.
Anyway...Getting closer to noise & smoke.
