Two days ago, I turned the ignition switch (key) to "on" but nothing happened.....turned off, jiggled the key and then it did turn on.
Today...riding along the bike quit dead.....rolled to the shoulder...turned off the key, then back on....it started just fine!
I've heard of issues with the ignition key switch from others....
If the issue continues and becomes a problem, I will do what I did for my cafe racer...just remove that huge honkin' switch mechanism, and replace with a waterproof toggle switch (or two switches if it is wired that way)
Cookie
