Author Topic: Your thoughts please?  (Read 1174 times)
Mikey82
on: September 18, 2024, 05:06:24 pm
I,m looking at a 2011 Bullet 500 very soon, the chrome version it’s been stood up but looks as though it can be sorted.
As I,m looking for a thumper bike, I,m thinking this may be the one but clueless.
It’s had a new speedo, it’s mot expired last year, it’s mot advisory was front brake binding not excessive adding up previous mots it’s done approx 8000 miles.
Seller is asking £1500 is that the going rate?
What do I look for ?
Paul W
Reply #1 on: September 18, 2024, 08:12:07 pm
Sounds like a very reasonable price.
Paul W.
Adrian II
Reply #2 on: September 18, 2024, 09:47:06 pm
2011 would be an EFI bike, so if you buy it, you should probably post some pictures in the Bullet with the UCE Engine section.
Mikey82
Reply #3 on: September 18, 2024, 10:15:32 pm
Thanks Adrian, didn’t realise it was an UCE so I have posted pics in the correct section
SteveThackery
  • Inveterate tinkerer
Reply #4 on: September 18, 2024, 11:19:34 pm
Sorry, Mike. I, too, thought it would be an AVL. I've messaged you accordingly.
Meteor 350
Previous:
'14 B5
Adrian II
Reply #5 on: September 19, 2024, 12:22:58 am
Some Electra-X models did sit in dealers' show rooms for a while after the EFIs came out, I saw one for sale on eBay with a 2010 registration. Handy for the ULEZ?
Mikey82
Reply #6 on: September 19, 2024, 06:34:40 am
How do I check if Electra x ?
year is 2011 any major differences this one def efi
Is Electra x a bad bike?
Thanks again
Adrian II
Reply #7 on: September 19, 2024, 09:12:53 am
The Electra-X has been sat in the naughty corner since 2006. The pictures you posted in the UCE section are definitely the later EFI model, an Electra-EFI de luxe by the look of it.
Do an internet search for Electra-X pictures, you'll soon see the difference compared to the 2011 bike. RE used the Electra name on several totally different models, including some Indian home market 350s.
SteveThackery
Reply #8 on: September 19, 2024, 09:48:21 am
Thanks again
The naming is complicated, as Adrian says.  It's easiest to forget about it and just think in terms of the three generations: iron barrel, AVL, UCE.
The iron barrel is closest to the original 1950s Brit bike, but the ones imported en masse to the UK have electric start. The AVL has a number of internal improvements, but still has a separate gearbox. The UCE is even better internally and is unit construction - the engine and gearbox are part of the same casting.  It came to the UK with fuel injection.
I my opinion (and it's unpopular) the iron barrel is indeed a "bad bike". The AVL and UCE are not.
You can easily tell the difference between the AVL and UCE: the former has a carburettor. Also, the engine castings are different - do some Google image searching to familiarise yourself with the differences.
It's important to emphasise that the Bullet and Classic are fundamentally the same bike - they differ only in the cosmetics. I think you would enjoy both, but you may find you have a preference.
Meteor 350
Previous:
'14 B5
El Saif
Reply #9 on: September 19, 2024, 12:11:37 pm
Even cast iron Bullet diehards admit that the 4 Speed Albion gearbox is crunchy with lots of false neutrals.
The AVL separate gearbox has 5 speeds, non - crunchy and has no false neutrals.
Retro fitting the separate gearbox with 5 speeds to cast iron Bullets is a popular modification.
Those who want to replace the cast iron Bullet engine with a diesel engine, prefer to use the separate gearbox with 5 speeds.
REgards
2004 RE Thunderbird 350cc AVL KS only
2021 RE Continental GT650 in Rocker Red
  • There are no truths outside the Gates of Eden
Reply #10 on: September 19, 2024, 12:26:37 pm
Thanks again
     My 2008 AVL Classic has the Electra-X engine (electronic ignition, electric starter, carburetor, 5-speed).
Electra-X factory inspection stickers are still all over my engine.
      The overall bike, however, is not an Electra-X. It is a Classic as it has a front drum brake, NOT disk.
       Your bike, Mikey, is the later fuel injection engine.
        Adrian, correct me where necessary.
« Last Edit: September 19, 2024, 12:31:21 pm by tooseevee »
Adrian II
Reply #11 on: September 19, 2024, 01:05:18 pm
No, you're bang on the money, there.  ;)
The AVL classic may have been down to pressure from Kevin Mahoney on the factory to come up with something that looked more like the classic Bullet. I think American buyers wanted the old style tool boxes and other tin ware rather than the slightly odd styling of the Electra-X. The UK and European importers never went for this, "You'll have the weirdo tool box and you will like it!" Many didn't...
Again the word "Classic" was bandied about a lot by the RE India marketing department. The early EFI 500s were the Electra-EFI in the UK which I gather were sold as the G5 Bullet in the USA, the Classic (EFI) came out shortly after which was the model C5. The Electra EFI and G5 continued the Electra-X styling, while the Classic/C5 had the traditionally styled tin ware and 18" wheels.
In the IB's later years the UK importers offered the following choice: 4-speed 350 kick start, 4-speed 500 kick start, 4-speed 500 electric start, 5-speed 500 electric start, but only as the Sixty-5 model in the UK (the US and Europe got the 5-speed E/S de luxe, as well as some Sixty-5s sold in the US), and the Electra-X 5-speed AVL 500. I went to the Watsonian-Squire open day in 2008 where they had the last of the dinosaurs on display.
Mikey82
Reply #12 on: September 19, 2024, 01:05:34 pm
Just like to say Thankyou for all the advise 👍
I bought it for 1250 needs a clean, but sounds very nice not tappety  as I expected and starts easily…
Now to get a new battery lots to choose from any help/advise welcome
Adrian II
Reply #13 on: September 19, 2024, 01:12:09 pm
Hydraulic tappets on the UCE models quieten them down if you like that sort of thing.
I'd go for a Motobatt MBTX14AU battery, but just go on-line and check the dimensions against what's already on there before you order.
SteveThackery
Reply #14 on: September 19, 2024, 04:22:08 pm
Yay! Good for you.
Meteor 350
Previous:
'14 B5
