Author Topic: sprag clutch  (Read 6058 times)
  • There are no truths outside the Gates of Eden
Reply #30 on: March 10, 2024, 11:11:39 am
Eventual was able to open up the the case . The sprag clutch I bought off Ebay is incorrect the part shown on Hitchcocks stated part number 560011 , the one I bought on Ebay said it was a direct replacement for 560011 ?  However I think the original part number should be #15 560042 it's held in with a circlip . Thanks for all your help guys .
            Go back to my Reply #10 in this thread where I pointed out the Ebay part might not be correct. It was only one piece of the total sprag clutch.
             Click on the link in my Reply #10. Part #14 in that exploded view is what you needed. Part #10 is what you got off Ebay & is only part of the whole AVL sprag clutch.
             Hitchcocks is a bit confusing now, I think. If you search on 560042 you don't get the correct sprag clutch for the AVL.
             Good luck with it. I'm gonna pull my old invoices later & I'll see exactly the Part # I ordered & see what I get when I search on that number.
Reply #31 on: March 10, 2024, 11:47:35 am
             Hitchcocks is a bit confusing now, I think. If you search on 560042 you don't get the correct sprag clutch for the 2008 AVL.
           I pulled my invoice dated 8-19-2021 & it was Part #560042 that was shipped to me.
           Then I went to Hitchcrocks and searched on 560042 & what you get a picture of is not what I got.
           So then I went to the Parts Book for 2008 Electra X & find that all the Part #s have been changed. The complete sprag is now Part #17 in the exploded view.
https://www.hitchcocksmotorcycles.com/partsbook-pages/6115
           So I give up. It's just giving me a headache. I think if you haven't already ordered it, you should call Hitchcocks. And this thread has now become kind of more confusion than it is help & I'm just gonna pull out of commenting any more. Perhaps you should start a new Subject Line & start over.
« Last Edit: March 10, 2024, 11:51:45 am by tooseevee »
African Boy
Reply #32 on: May 12, 2024, 08:36:11 am
 It wasn't the correct sprag clutch . It was for the later Classic EFI bikes . I have since received a complete sprag clutch but the cut of the teeth or not the same as the original !  Maybe dump the idea of the sprag clutch and just use the kick start .
African Boy
Reply #33 on: June 17, 2024, 11:56:43 am
There was no sprag clutch in the bike when I got it . I have eventually got the correct sprag clutch and it's working .
   Many thanks for all the help and advice .
