In another thread, oil changing and levels are being discussed. Here's a post from our friend caricabasso:
We must remember that the connecting rod chamber is closed to lubricate the best crankshaft and piston.
The oil is then catapulted from the crankshaft rear to the transmission gears.
From the picture you can see how much oil remains on the chamber connecting rod, that is, 900 c.c.!
This can cause errors in the reading level.
I think we can all agree, that's a lot left behind when you're trying to change your oil. Conventional wisdom calls for tipping the bike side to side to help drain behind the side covers. I've been trying to sort this out myself lately (having access to an open engine case) to improve my oil draining, to see how the second drain plug added by the factory would help - and to see whether a second plug might be fitted to the earlier UCE.
As many of you know, I don't know much about what I'm doing here, so this
isn't a tutorial or anything - I'm just throwing it up for discussion!
Anyway, here's some photos I took, and annotated to show my understanding of what's happening - and why I'm not sure how tipping the bike helps drain the oil...
As caricabasso reminds us, when the engine is running, the spinning crank throws oil from the crank chamber up and back to lubricate the transmission.
So, first is a pic of the inside of the right-side engine case, showing the crank chamber and the oil sump:
To the lower right of the photo, you can see the small dark circle which is the sump drain plug opening - but notice that there is no opening to drain oil from the bottom of the crank chamber.
My green line traces where the cases are glued together, so no oil drains into the sump anywhere along that seam. The blue arrow shows the
lowest passage out of the chamber on this side - the shift lever shaft passes through here. No oil below it can drain anywhere. The yellow arrow shows a lower passage, but it's between sump and the outside of the case (behind the right-side engine cover).
Here is the outside of the right-side engine case:
The blue arrow shows the shift lever shaft passage from the previous photo - I've got a light behind it to show it clearly. Also note the yellow arrow marking the same lower passage back to the sump - any oil finding its way from the crank chamber through the shift lever shaft passage (no seal there, so it could happen, I suppose) will obviously run into the sump through the "yellow" passage - but neither passage drains the crank chamber, as seen in the first photo.
I'm not sure what happens with the engine cover on this side, but it appears that oil towards the front of this area, beneath the cams and stator/rotor, will remain captured by the short rearward-tilting baffle plate just to the right of my yellow arrow - the gasket seals this to a matching web in the cover casting. So I don't see how tipping the bike (a common suggestion for oil changes) helps drain much of any oil from this outer right-side chamber.
To the inside of the left-side engine case:
Another green strip, tracing where the cases are glued together, so no oil drains into the sump along that seam. Another blue arrow, showing the matching shift lever shaft passage between the left inner and outer cases. This time, however, the red arrow shows a lower passage between the left inner and outer cases, where oil can pass through...
outside of the left-side engine case:
... but as we see at the red arrow, that passage is at the bottom of the left-side outer case - and it's the lowest passage for any oil to pass out of this chamber. The high "blue" passage is visible here, too - and there are no other passages I can see which would drain oil into the sump from here. Again, I don't see how tipping the bike either way would help drain any oil at all from this outer left-side chamber. Any oil in this chamber "should" drain through that "red" passage into the crank chamber, but there's nowhere for it to go from there.
As for a second drain plug? Well, here's another pic with some different arrows:
If I recall correctly, the new second drain plug is installed on the flat of the sump, where the pink arrow is, so unless the interior of the casting was changed (no reason it couldn't have been!), it wouldn't drain the crank chamber, just the front end of the sump. On the surface of it, this seems of limited usefulness, since the only obstructions keeping sump oil from draining are the cast fastener cavities (yellow arrows) which keep just a small amount of oil captive. A plug which would drain the
crank chamber would need to be somewhere just ahead of the sump, like the blue arrow shows - but I don't know about whether it could be done safely there.
All of which led to my post in that other thread:
So, what about draining the oil from the sump, so it won't continue to circulate, and then cycling the engine - just a few turns - maybe without the spark plug installed to encourage faster turning, to try to throw some of that oil out of that chamber? Waste of time, or worth a try?
