First thing I did was lower the stanchions so they do not protrude above the upper triple clamp/tree. Looks so much better on the INT, and does not make any appreciable difference in handling IMO. In fact, I think this change helped to eliminate the head shake that many members experienced, blaming the brazilian Pirelli's. I kept the OEM tires, and often ride up to 90 MPH, stable, no shake. The raised protruding stanchions makes the front look a bit short and stubby to me. Maybe it works better on the GT.
Then again, don't crucify me- Raised on chopped Triumphs with extended forks, so I'm biased.
