Author Topic: intersceptor fork height question  (Read 326 times)
a10ken
  • barrow in furness uk
on: May 02, 2021, 11:38:31 am
hi folks, does anyone have the fork height measurment from the top of the fork (not including the dust seal) to the bottom of the lower yoke (tripple tree) with the fornt wheel of the ground. ta.
interceptor 650
xl1200s sport
buell m2
k75
mt500
f650
Breaker Express
  • Ocoee, FL USA
Reply #1 on: May 02, 2021, 04:21:51 pm
10 mm
2020 Baker Express
Voun
  • So far so good ...
  • 2021 Interceptor
Reply #2 on: May 02, 2021, 05:19:49 pm
12 mm on mine, I don't think it's a matter on 1 or 2 mm.
Breaker Express
  • Ocoee, FL USA
Reply #3 on: May 02, 2021, 05:42:35 pm
I did mine at 11mm, however, the service manual states 10mm
2020 Baker Express
Jack Straw
  • Prescott, Arizona
Reply #4 on: May 02, 2021, 05:53:57 pm
The top fork protrusion on my Interceptor is 10mm to the top of the stanchion rather than the cap, measured at  the slot in the top clamp.  Be aware that the top clamps are not always consistent.  Some are flat, some have had a taper front to back so measure at the same relative location on either side.
Voun is right  in that a couple of silly millimeters is not an issue.   I've seen photos showing the stanchions set flush with the clamp which in theory may make the steering a bit slower/less twitchy although different rider and tire combinations can render the issue moot.
Interceptor 650, Honda VT500 Ascot at present
Norton Commando, Ducati Diana Mk. III, CB 500/570, KLR 650, Ducati 250 Scrambler, CB 350, Honda S 90, YDS-3, SV 650 and a few others in the past.
biscot
  • Idaho, USA
  • 2020 Baker Express
Reply #5 on: May 02, 2021, 10:09:38 pm
I believe the OP asked for the distance to the bottom of the lower yoke of the triple tree (although he could probably figure it out from the information given). I'm not in my garage so I don't have that measurement.
Voun
  • 2021 Interceptor
Reply #6 on: May 02, 2021, 10:41:57 pm
Hey guys, sorry for this out of topic question, I understand the meaning but what "OP" spells for ?
Hoiho
  • Engorged Member
  • NZ - 2020 GT 650
Reply #7 on: May 02, 2021, 10:49:31 pm
Original Post  ;)
NVDucati
  • USA 2020 INT
Reply #8 on: May 02, 2021, 10:50:53 pm
OP = Original Poster, (person who started thread)
Member: AMA
Current Rides: '14 DL1000 ADV, '06 SV650N, '93 900CBRR, '74 Ducati 750GT
BlackIce619
  • San Diego, California
Reply #9 on: May 03, 2021, 05:03:13 am
I just did the YSS fork upgrade and my height (which I had to put back) measured 12mm.
2019 RE Continental GT 650 - Ice Queen
Bibbage
  • Suffolk UK
Reply #10 on: May 03, 2021, 10:35:46 am
With bike on side stand mine is roughly 124mm.  Hope this helps.
Current Bikes:-
Interceptor 650 (Baker Express)
Triumph Speed Twin 5TA (1966)
Past Bikes:-
Honda S90 (first bike)
Honda CB160
Triumph T21 3TA 350
BSA Bantam 150
Suzuki 80
Honda CB125
Honda Super Dream 250
Triumph Legend 900
Suzuki GSX750F
Voun
  • 2021 Interceptor
Reply #11 on: May 03, 2021, 11:29:46 am
Thanks Hoiho and NV  !
a10ken
Reply #12 on: May 04, 2021, 11:37:57 am
hi folks, thanks for the reply,s.
i think i should have made myself clearer in my first post, i have made some internal changes to the forks but forgot to take a measurement of the standard distance between the lower edge of the bottom yoke (tripple tree) and the top of the fork slider.
ie: bike on center stand with front wheel raised of the ground so under no load.
cheers
interceptor 650
xl1200s sport
buell m2
k75
mt500
f650
agagliardi
Reply #13 on: May 04, 2021, 12:16:53 pm
First thing I did was lower the stanchions so they do not protrude above the upper triple clamp/tree. Looks so much better on the INT, and does not make any appreciable difference in handling IMO. In fact, I think this change helped to eliminate the head shake that many members experienced, blaming the brazilian Pirelli's. I kept the OEM tires, and often ride up to 90 MPH, stable, no shake. The raised protruding stanchions makes the front look a bit short and stubby to me. Maybe it works better on the GT.
Then again, don't crucify me- Raised on chopped Triumphs with extended forks, so I'm biased.
1988 Super Magna, 2000 Harley Softail, 2004 Hayabusa,
2020 Royal Enfield Interceptor, 2004 Corvette
YellowDuck
Reply #14 on: May 04, 2021, 01:27:13 pm
Ha ha nothing wrong with a little ride-height adjustment.  But 12 mm is quite a bit to lift the front of any bike.  Proof is in the pudding - if it works for you, then it's a good thing!  Also, depending on your rear pre-load setting, you may not be that far off the intended rake, just a bit higher off the ground.
