The Himalayan final drive chain is a 525, according to this fellow:
xxxxxxxxxxxxxx
https://advrider.com/f/threads/royal-enfield-himalayan-owners-thread.1253460/page-741My USA 2019 Himalayan chain is a 525------with 110 links.
I'm just putting this out there in case you are going order a new chain and glanced at yours and just thought it's a 520----it's not. Most bikes this size I've owned would have a 520--but this bike has a 525.
Knowing how chain sizing works is interesting.
The numbers always refer to increments of 1/8"
If the first number is a 5---------it means it's 5 times 1/8"----------or 5/8" (pin to pin)
If the second is a 2----it means 2 times 1/8"---------------which is 2/8" ---which is 1/4" (this is the inside roller length)
So what about a 525 size-----how does that work ?
First number is a 5----so the link is 5/8" long ---pin to pin.
The second 2 numbers are 25---what the hell does that mean It means 2.5 times 1/8"--------which is 5/16".
So our chains are 5/8" X 5/16"
No metrics with motorcycle chains.
Clear as mud------------read all that again--------------very sloooooooowly. Took me awhile to get it.
BigDog
xxxxxxxxxxxxxxxxxxxx
So any chain longer than say 114 links will work, just cut to length, grind off the necessary rivet head and drive it out. The standard DID's are tough & economical, maybe $40ish, I'm not a big fan of O-ring chain anyway. Mostly a way to hold in water & rot the chain, IMHO. Lube early & lube often, I say. E-Bay & Amazon are sources for half links. (
https://www.feked.com/ ) is another good one. If the chain lifts about 1/2 half of a tooth up off the sprocket (backside test, full contact area, checks for net wear/stretch) it's on it's way out anyhow. If the teeth aren't fish hooked, a new chain will allow you to get whatever life's left from the sprockets.
https://www.wemoto.com/info/chain_dimensionsMetric Dimensions
Chain Pitch Width Roller Diameter
415 12.70mm 4.88mm 7.75mm
420 12.70mm 6.35mm 7.75mm
428 12.70mm 7.75mm 8.51mm
520 15.88mm 6.35mm 10.16mm
525 15.88mm 7.85mm 10.16mm
530 15.88mm 9.53mm 10.16mm
532 15.88mm 9.53mm 11.10mm
630 19.05mm 9.53mm 11.91mm
632 19.05mm 9.66mm 12.68mm
Side plate thickness varies with grade and make of chain. As a rule, 1.5 to 2.6 mm. It is important for safety to join chain with the manufacturers correct Rivet Soft Link or Split Spring Link.
Size, Manufacturer, and grade are often stamped on some of the side plates.
