But this author described EXACTLY what I feel on my bike...
So I guess we are both full of shite?
Cookie
NOT AT ALL ! I am not suggesting that you are wrong. I think you know that I went all the way and spent $600usd to convert the front suspension on my bike to a cartridge system. I was commenting on the nature of moto journalists. Also I'm saying that these front ends can be made much better by means that are fairly simple and not as radical as I chose to to do.
First off would be to change the fork oil. The fork oil in my bike was actually more like motor oil than fork oil or ATF. AND the oil in each fork was different from the other.
- Depending on ones weight and how hard you charge the corners, you can go with different viscosity and/or volume fork fluid.
- Another quick and easy improvement is to replace the fork caps with ones that have preload adjusters. Think of them as variable spacers.
- Next up is different springs and emulators
- Then all the way to the conversion to the cartridge. That is like having upside down forks that are still right side up. And adjustable for compression, rebound and preload.
I know that a lot of people say that this all should be done at the factory. But it is not. It is also not done by Suzuki, Honda, Yamaha and others for their cost sensitive models. With a few exceptions, I have gone through this with a lot of motorcycles. And even the ones that came with high end forks, I still had to refresh the fork oil periodically.
Personally, I'm glad that RE directed the available budget at SS braided brake lines, Bosch electronics, super duty crank bearings, etc.
Some folks will be happy enough just to get rid of that annoying click/clank of the lower damper cone spring. Others want still more suspension performance.
Just know that I was in no way criticizing your opinion.
