I have not seen the EFI system on these bike's. But a fast idle at a cold start up would be normal with EFI.... You probably noticed it on your car . Particularly when it is cold. Somewhat similar to pulling a choke on a carb to get the motor up to operating temp quicker. But I imagine these bike's may have a stepper motor , that controls the throttle plate, or a by-pass around the throttle plate, in the throttle body , to crack it open more when the motor is cold. Not sure ? And if these motors have as good an oiling and cooling system on them as the UCE's do ? And it looks like they are better, with that oil cooler added. Then it can take quite a long time in cool or cold weather for the motor to get up to operating temps. So if you were to return to idle , before the engine was at operating temp... the idle may still be high. The 1200 rpm's at a hot idle .... i'm assuming.... is probably what the bikes battery and charging system needs to run the EFI system with enough power at idle , and to not drain the battery. The output from the alternator should be RPM dependent...
