I’ve fitted sets Of LED indicators to many bikes, most of them I’ve replaced with an LED relay, some of these relays are adjustable for flash rate, the only model I’ve come across that has to have ballasts was a 954 fireblade because the relay was built into the clocks, also these ballasts need To be fitted to heat sink, the value of the ballasts were 6ohm 50w.
