Author Topic: What did you do to your bike today?  (Read 289726 times)
om15
Reply #105 on: April 17, 2021, 12:21:23 pm
A good clean, 70 mile run in the sunshine and then had its photo taken.
current bikes
 2001 Bonneville 790,  RE Bullet 500 UCE
Previous, RE Classic 500, Classic 350 , RE Himalayan 2019, RE Interceptor 2020.
Triumph Trident 900, 2003 Bonneville 790 , Adventurer 900, T100 Bonneville, Street Twin. Tracer 700.  BSA C15, Yamaha XT500
Retired aircraft engineer South West
BlackIce619
  • California
Reply #106 on: April 18, 2021, 06:39:19 pm
Bubble Bath!!!
2019 RE Continental GT 650 - Ice Queen
Breaker Express
  • Ocoee, FL USA
Reply #107 on: April 20, 2021, 01:56:37 am
Finally wired up the moto gadget turn signals at the front. Now I have to do the rear on Wednesday.
2020 Baker Express
BlackIce619
  • California
Reply #108 on: April 20, 2021, 08:49:13 pm
Ordered Hagon rear shocks, front fork preload adjuster, heavier 10% fork springs, iridium spark plugs, engine guard, grips, brass valve caps...
Trying to find tires in USA. Ongoing issue...
So far my best search for road/track use here in California is...
Bridgestone BT54
110/80/18
140/70/18
I will put a build thread soon. Nothing crazy.
Hoiho
  • Dead horse beater
  • NZ - 2020 GT 650
Reply #109 on: April 20, 2021, 09:45:48 pm
Bridgestone BT54
110/80/18
140/70/18
Hitchcock +10% prog fork springs were a fail for me. They were shorter than stock and compressed more easily, I'm going linear after installing the PD valve emulators.  +20mm Hagon on the other hand are brilliant - love the extra travel and control.
I think your tyre sizes are perfect for the GT. Bit of extra width helps with grip and slightly lower front profile helps with turn in. I find my bike holds a line much than mate's Intercepter on stock rubber (new set) which seems to step out on corners more easily.  Try and get the newer BT46 if you can.
BlackIce619
  • California
Reply #110 on: April 20, 2021, 10:30:47 pm
Hitchcock +10% prog fork springs were a fail for me. They were shorter than stock and compressed more easily...
I hope Hitchcock gets my email and makes that change for me. I ordered today and requested to cancel the 10% stiffer spring. Will go with preload adjuster and fresh oil or 15w and see how that holds up for now.
Have not purchased the tires yet, but trying to just find something available.
Truly appreciate the advise!!!
BlackIce619
  • California
Reply #111 on: April 20, 2021, 11:34:32 pm
FML... They really don't want you to have quality tires here in California.
I found the sizes I need but they are both Rear tires . No Front available. Hahaha
NVDucati
  • USA 2020 INT
Reply #112 on: April 21, 2021, 04:21:48 am
When you look at the photo it appears to be a front with a typo. Phone Revzila they are good at customer service.
There are some folks who run 150s on the rear. Maybe the Bridgestone users can verify. I have a 150 Avon on mine.
Member: AMA
Current Rides: '14 DL1000 ADV, '06 SV650N, '93 900CBRR, '74 Ducati 750GT, '14 Honda CB1000-R
BlackIce619
  • California
Reply #113 on: April 21, 2021, 05:56:52 am
I just called a local Bridgestone distributor. They confirmed they can order me Bridgestone BT46 and will be available in 2-3 days.
110/80/18 - $140
140/70/18 - $110
Not a bad deal and first time ever a front is more expensive than rear.
Side note: sent Hitchcock an email to change my front suspension order from a Fork Adjustment to YSS kit. Might as well spend the money and have a bigger smile on the track than regretting my purchase. Thank you Hoiho!!!
Hoiho
  • Dead horse beater
  • NZ - 2020 GT 650
Reply #114 on: April 21, 2021, 07:00:04 am
110/80/18 - $140
140/70/18 - $110
Nice. I think the 110/80 front has a higher speed rating, V vs H rear?
BlackIce619
  • California
Reply #115 on: April 21, 2021, 06:43:30 pm
Yes, you are exactly correct. Price difference for that tire from local distributor was $10. The other thing is the H is only available in 110/90. I will keep the 110/80 for $10 more and just remember to only go fast on front tire  :o
Karl Fenn
Reply #116 on: April 22, 2021, 04:23:06 pm
Well today l got brand new brake calipers Co Royal Enfeild.
Voun
  • Camembert électrique
  • 2021 Interceptor
Reply #117 on: April 22, 2021, 06:26:08 pm
Nothing but checking the tire pressure and go for a drink with Captain Haddock in Moulinsart ...
Blazes Boylan
  • Brooklyn
Reply #118 on: April 22, 2021, 07:01:37 pm
I have no trouble seeing Tintin on that bike.
Voun
  • 2021 Interceptor
Reply #119 on: April 22, 2021, 10:22:58 pm
