It turned out to be pretty easy to test. I'm getting 6 long and 6 short which suggests the crank position sensor. Sounds like I'll have to take it into the shop. I might try resetting the MIL error code and see if it still happens.
I should also of asked if they could connect the lower rubber strap that holds the battery (how the hell does that go back on?).
