The old man back again.
Learned heaps about my Bullet in the past few days.
I did an oil change using 2.75 litres and it vomited oil out the air filter housing.
Read the service manual a little more carefully and replace the oil with 2.4 litres and it vomited that out too.
I started to think I had a blowby problem but it happened too fast and coincidentally with the oil change.
Dropped the oil again and measured 1.65 litres..........
Before I dropped the oil that was left I looked into the sight glass and could just see the oil level at the top of the inspection glass.
I had a good look at the inside of the RH crank case cover and I didn't belive there was any way to get a true reading in the inspection glass the way the baffles in the cover are arranged, so I milled a 3/16th hole through the baffle immediately beside the inspection glass so a small amount of oil is fed to the inspection glass chamber actually allowing the oil level in the case to be represented in the inspection glass without upsetting any dynamic flow which may exist around the baffle.
I use Morey's oil stabiliser 15% in the oil and it has seriously reduced the vibration.
"Roy" (my bikes name) now cruises so smoothly at 100kmh it is crazy.
I took a young bloke for a ride and he said the unbelievable words, "this bike runs really smooth."
I might record him saying that and put it on youtube
When we got home, no oil blowby. Need a new rear sprocket and chain.
The rear sprocket is missing a few teeth and looks like an old man smiling.
Re the piston it is from an RB30 turbo high silican job BUT I need to mic it up and measure pin height and diameter for suitability.
Forged pistons are strong but heavy but high silicon hypereutectic types are fine for the piston speed this engine will see.
The Japanese have made an art form of seriously strong high silicon pistons for decades.
I will keep you posted about all this.
I have an aluminium con rod I am dressing at the moment.
It was the roughest thing I have ever seen come out of a box for immediate use.
Shameful.
Just for something to do between beers, I degreed up the standard camshaft in a 2013 Bullet 500 to get the specs.
Because of the woeful amount of technical information I am kind of making a maunual of specs as I go.
Do they have LSD in India?
Because the specs on these cams are beyond weird. The bloke who designed the grind must have been having one of those transcendental guru moments when he put this one on paper
I have seen tougher grinds in Briggs and Stratton side valve engine !
If anyone wants the specs..................
Okay that's it for now.
I have done my job as an old man and talked too much.
Hope I'm still on topic............I do drift a bit......but mainly only on dirt roads
