Spent awhile giving the Electra X more love. Front End all done!
http://s147.photobucket.com/user/Heloego24/library/Bikes/Electra%20AVL?sort=3&page=1 Dyna Beads on the way. I'll change out the rear Skidmaster for a K70, then add the Dyna beads to both.
The HF Tire Changer and Motorcycle Accessory work out
very nicely!
Still to do: Rear tire, Tank 3D decals, engine rings, thermal coatings for the head and barrel, polish all covers, install Goldstar exhaust system, and play with carb(s).
I think I'm in love again. And the missus knows it.
Just thought I'd mention...
I installed a stainless brake hose kit and bleeding the system yesterday was a real PITA. I was using my vacuum system to do it and never could get the system to bleed properly. By the end of the evening I just kept recycling nice clean fluid.
So I canned the vacuum setup and after a thorough cleaning and
fill of the caliper mounted it, loosened the hose at the caliper banjo and cycled fluid through the reservoir until I was getting only fluid at the banjo. Snugged her up and began pumping the brake handle watching bubbles rise out of the piston relief and filler holes.
Lo and behold! Within 5 minutes I was getting pressure and a minute later my brake is done!
Don't know why I didn't think of it last night.
