Assuming one wanted to take a stab at port and polish to improve the flow, what is the next size larger throttle body that will bolt on and what bike do we salvage it from ?
Michael.. Brother... would you be referring to that cookie cutter , pre-made cafe racer GT thang ?! And, it's ... It's.. bucket sized TB ?! Hehehehehehe
NO... I think with the stock ( pretty narrow) rev range, or even a bit north of that stock rev range, the stock UCE 500 TB is good. Sure, you'll get more volume ... but at a slower speed. And you will likely, ONLY feel an improvement in the top end, and when ringing it's neck ! My humble opinion, from us working and tuning on this 500 cc motor for quite a long time now.... is that speed, velocity and time BEAT volume. Unless that is, IF you want to rev it to the moon and stay up there... and Race ? Throw some money at that bottom end to !
When that stock intake cam opens that valve with the 34 mm GT TB, it will be at a slower rate and there will also be no help from the stock exhaust cam profile with pulling in the next incoming charge of react-able mix... IMHO anyways. Do the port and and polishing and keep the stock TB. When I said intake, I meant to free it up and or lengthen it.
