Very interesting. What model Enfield? You just cut the ribbed collar off? I notice the flange itself is cracked. I am assuming you welded the crack in the steel flange? It looks like the studs got bent from the nuts being overtightened. The studs on mine keep coming loose. However they are not bent. I have not tightened then really tight because I was afraid of stripping the threads in the head or breaking a stud off in the head. You say it was that way when you bought the bike? Did anything ever come loose? It looks like things do not line up properly is what bent the studs. Did you replace the studs? I'm thinking about using bolts instead, and possibly drilling the heads for safety wire, so they will be mechanically locked in place. I also need a new gasket, mine leaks a tiny bit, from being reused so many times. I suppose I will have to order one from the dealer 120 miles away, then wait a few weeks for it to come in. Do you or anyone else know of an alternative? Harley Sportster gaskets are a perfect fit on my Kawasaki Vulcan 750.
Mine is the Standard B5 of 2012.
The exhaust gasket is made of cardboard type asbestos with a metal core.
Should put a seal mixed copper-asbestos (asbestos or type) of the same size.
I do not think difficult to find at aftermarket car or bike, also available from retail marine engine spares.
To remove the aluminum part just make a cut with a saw and then expand with a wedge.
It should however protect the exhaust manifold by inserting a blade of aluminum or iron between the flange and the tube to avoid marking with the blade.
Once removed the aluminum collar remains the iron part that I then shortened.
With the welding I reinforced everything.
We here in Italy several Royal Enfield show that defect, that is, the bending of the flange.
My impression is that the bolt of the right to remain shorter than the left for an incorrect alignment of the flange.
In fact, as can be seen from the photographs, after repairing the folding of the flange and reinforced with the carry the welding, right now the bolt remains shorter than the left one.
Probably during assembly at the factory is a tendency to tighten more to the right until it pops out from the nut.
This involves the bending of the flange and the bolt.
I have not replaced the bolts bent have them repaired by blocking the vice beating with a hammer after putting the nuts to protect the thread.
However, it is advisable to replace them.
To ensure a good locking bolts used to put the thread of this product and it works well from Bostik threadlocker resistant up to 1250 ° celsius
http://www.ebay.it/itm/BOSTIK-SIGILLANTE-CAMINETTI-E-STUFE-MASTICE-REFRETTARIO-SIGILLANTE-FINO-A-1250-C-/131069657340
