Author Topic: What did you do to your Royal Enfield today?  (Read 1855534 times)
0 Members and 15 Guests are viewing this topic.
ToesNose
  • That goes where? Mooresville, NC
Reply #5385 on: January 05, 2015, 12:19:14 am
Rainy and quite windy here today so I decided to pull the headlight jumper out from the bucket,  anyone know what the extra two wires are at the headlight?  Possibly for the H.I.D. option in India?
"Pardon me...do you have hot sauce for this?"
2007 Suzuki LS650
2014 RE C5 Tan 'Manjika'
Reply #5386 on: January 05, 2015, 12:35:51 am
I removed the tool EFI and put the ammeter.
Does it work?  How did you connect the wires?
Reply #5387 on: January 05, 2015, 12:37:48 am
"Parking" light?  If it's like mine, you'll find the pair has power whenever you switch on the lights to the "parking" position... or the full-on position, too, of course...
caricabasso
Reply #5388 on: January 05, 2015, 05:47:16 am
No, not yet.
It will connect tomorrow, meanwhile, put the lights on and the fuel control unit with two holes in the nacelle.
suitcasejefferson
Reply #5389 on: January 05, 2015, 05:57:51 am
Went for a ride, about 50 miles. It was pretty cold. Mid '40s. Again, I lost a nut off the header pipe to head joint. The engines sound changed suddenly. Fortunately I had another one, and a wrench. I have not yet found a solution to this problem. The area is way to hot for any kind of thread locker, it just melts. Still trying to find some kind of mechanical means to secure them. There are two things to secure. The nuts come loose on the studs, and the studs come loose in the heads. Maybe the only solution is to snug them up every couple hundred miles. I have ridden with Harley riders back in the early '90s who had to pull over every so often to tighten their engine mount bolts. Guess I have been spoiled by those "reliable" Japanese bikes.
"Buy the ticket, take the ride" Hunter S. Thompson
crock
Reply #5390 on: January 05, 2015, 06:12:29 am
You should try Loctite 2422 which is a high temp version of the blue thread locker good to 650 degrees. You can get it on Amazon for about 35 bucks delivered.
Rocket
Reply #5391 on: January 05, 2015, 11:12:53 am
Or you could try hi temp silicone on the threads.
azcatfan
  • 2002 Bullet ES
Reply #5392 on: January 05, 2015, 01:55:44 pm
Met up with a friend that has on old KZ400 cafe style and went for a ride.  After the snow in the desert last week, the weather has been perfect B-)
https://www.youtube.com/watch?v=FOYNd-1M9HQ&list=UUQ07mbkbFRRntZh4_P81Ktg
pmanaz1973
Reply #5393 on: January 05, 2015, 04:28:26 pm
Get two stainless replacement drilled nuts or have your existing nuts drilled by a machine shop (Wow! That sounded bad  :o).  Then you can thread some safety wire through them. Mechanical solution and shouldn't cost very much.  Google "drilled jam nut" and you see what I'm talking about.  I've done this before on a Harley and it worked great.
1984 XL350R
1991 XR250L
1976 Harley XLH 1000
1993 CBR 600
1976 Norton Commando 850
1972 BMW R75/5
2014 Royal Enfield C5
Reply #5394 on: January 06, 2015, 04:55:43 pm
Got the new cable ends installed on the clutch and front brake cables.  The new controls are finished now.  :)
Mr.Mazza
  • Upside down thumping
Reply #5395 on: January 06, 2015, 07:26:25 pm
Stripped and cleaned my new-old rearsets for my bike, I was gonna paint them but polished alloy looks cool!
I also saw at least 100 riders today (perfect riding weather for the whole month) and am sad I dont have a running bike :(
heloego
  • USA '12 C5, '06 ElectraX
Reply #5396 on: January 09, 2015, 10:39:08 pm
OEM pos battery gave up the ghost.
Picked up an AGM locally from Interstate Batteries and I'm back in business.  :D
'12 C5 Classic
Reply #5397 on: January 09, 2015, 10:56:42 pm
Finished the new exhaust system today and wrapped it.   :)
« Last Edit: January 13, 2015, 12:11:13 pm by High On Octane »
akbled
Reply #5398 on: January 12, 2015, 04:25:45 pm
Let's see, yesterday I lubed the chain and fixed an exhaust leak after replacing the torpedo with the megaphone.  I pulled the headlight jumper.  I also bent a heavy duty negative battery terminal about 45 degrees.  I had replaced this one when the stock one sheared off.  The new one was putting pressure on the post from the frame and actually broke the the negative post on the stock battery a short time ago.  I spent some time trying to figure out a front wheel squeak I was getting.  Assumed it was the brake, and tried to clean it well with some brake cleaner.  Didn't notice any squeak this morning but may have to take it apart if it comes back.
krimp
Reply #5399 on: January 12, 2015, 05:26:10 pm
This morning, I stared at her sitting there in the snow and longed for the day when she and I could go for another ride.
Living in beautiful Colorado Springs, Co.
2014 Cream C5
