Author Topic: What did you do to your Royal Enfield today?  (Read 1855351 times)
0 Members and 13 Guests are viewing this topic.
Reply #5370 on: December 28, 2014, 01:45:58 pm
I thought the friction dampers were okay. All my Ducatis had them. I never really noticed any problem.
Home of the Fireball 535 !
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
Reply #5371 on: December 28, 2014, 04:09:19 pm
I keep my damper very tight.  As in, about a 1/4-1/2 of a turn from from being completely bottomed out tight.  The only time it ever caused an issue was the very first time I went around the block, I didn't know what the damper was, so just tightened it.  I almost dropped the bike 3 times before I realized what I did.
On my machines that had friction steering dampers I was comfortable with just a wee bit of tension for average riding, & slightly more for Highway. To much friction would cause the rolling Steve Thackery mentioned.  Sidecar use requires even more tension. My Russian rigs would shake their head at 19mph, This would go away at 21mph. It was un-noticeable if you were accelerating quickly past this speed.
  Friction damping goes far back in motoring history. Motorcycle girder forks & springer forks would rely solely on friction rebound damping before Hydraulically damped shocks were made. Antique autos with leaf springs were fitted with knee action Friction Dampers on all corners, that served as shock absorbers. I owned a 1949 MG that had them.
  Friction Dampers on motorcycles work pretty much like the Hydraulics, but are much simpler & more compact. They are intended only to produce as much drag on the steering (as determined by the rider) to overcome various road conditions & aid the rider in controlling his machine. I think hydraulic dampers are unwieldy & wouldn't use one if it were a gift.
Best Wishes, Craig McClure
ruufman58
Reply #5372 on: December 29, 2014, 06:32:30 pm
I spent 2 hours installing a power commander and it actually started on the first try
2013 G5Deluxe riding since 72
SteveThackery
  • Inveterate tinkerer
  • "If it ain't broke, keep fixing it until it is."
Reply #5373 on: December 29, 2014, 07:15:04 pm
Thank you, Craig - I was obviously setting them too tight.  Mind you, I'm not sure they were really necessary on the Z1 or the Ducati, because both seemed fine with the damper backed right off.
Meteor 350
Previous:
'14 B5
'06 ElectraX (Good bike, had no trouble at all)
'02 500ES (Fully "Hitchcocked" - 535, cams, piston, etc - and still a piece of junk)
...plus loads of other bikes: German, British, Japanese, Italian, East European.
Reply #5374 on: December 30, 2014, 02:51:36 am
I turned my dual exhaust into a 2-into-1 exhaust!  I was nervous cutting it up but it actually came out really great.  :)
« Last Edit: December 30, 2014, 03:05:22 am by High On Octane »
ToesNose
Reply #5375 on: December 30, 2014, 01:00:27 pm
Wow! The two into one came out really clean looking, top notch Scotty.  ;)
2007 Suzuki LS650
2014 RE C5 Tan 'Manjika'
ToesNose
Reply #5376 on: January 01, 2015, 10:19:23 pm
I swapped the stook grips for the Amal style ones,  so much better with the ticker grips raised in the center, I've always found flat thin grips to fatigue my hands.
2007 Suzuki LS650
NorEaster
Reply #5377 on: January 01, 2015, 10:32:02 pm
passed through my garage for the "umpteenth-million" time staring longingly at my bike... wishing I could just hop on it and ride away  :-[
winter sucks
« Last Edit: January 01, 2015, 10:34:51 pm by NorEaster »
Reply #5378 on: January 01, 2015, 10:52:08 pm
Me too....    :(
pmanaz1973
Reply #5379 on: January 02, 2015, 04:33:42 am
+1 with a beer in my hand
1984 XL350R
1991 XR250L
1976 Harley XLH 1000
1993 CBR 600
1976 Norton Commando 850
1972 BMW R75/5
2014 Royal Enfield C5
Reply #5380 on: January 02, 2015, 04:48:47 am
Rode the SV today.  It was supposed to be a small group ride but no one else showed :(  Still a nice ride.  Just above freezing and clear.  Only a spot or two of ice in the hills.
crock
Reply #5381 on: January 02, 2015, 07:11:54 pm
Installed the Power Commander PCV, the Nfield "Sport" exhaust system, and the Scott chain oiler. Fired off on the first kick! Sometimes I impress myself. Now if only I could figure out how to post the pictures...I'll give it a try next week.
Rocket
Reply #5382 on: January 04, 2015, 05:10:46 am
I turned my dual exhaust into a 2-into-1 exhaust!  ........
Y ?
Reply #5383 on: January 04, 2015, 05:38:41 am
Y ?
Better performance, less weight, and less of a PITA when I need to get into the primary cover.
caricabasso
Reply #5384 on: January 04, 2015, 10:33:48 pm
I removed the tool EFI and put the ammeter.
