Today I serviced the front end. I removed the forks and cleaned them and changed the fork oil, removed the steering yoke and re packed the bearings with fresh grease, replaced the rubber boots, one of which was split ,tidied up the wiring behind the headlamp, lubed the speedo cable , and cleaned up the front wheel . Tomorrow I will service the brake calliper . Looks so much nicer clean !
