The last couple of days, I've been working on my bike; oil change, fix the seeping in the timing case joint, putting on an 18T sprocket and a new O-ring chain.
All did not necessarily go well staring with the sprocket change. It started when I could get the nut off mostly because I didn't have the proper socket. I tried other tools, a big crescent wrench. That slipped and crunched my little finger into the rear foot peg, ripping most of the hide off a knuckle. Had to waste time bandaging that up! Then I tried a chisel, wouldn't budge it. So that means a trip and another hour or so wasted going to harbor Freight. I got a 3/4" drive Metric socket set from 19MM to 50MM. 47 Bucks. At least the price was tolerable. I came back home and cranked the brake pedal down to stop the wheel from turning while I'm trying to get this nut off. The wrench would still turn the wheel. I stuck a bolt in between the sprocket and chain. That finally got everything stopped and I finally got the nut off with the assistance of a fork leg tube that serves as a BIG breaker bar. It's starting to get late and I ave to fix dinner for my wife so I clean myself up and got the dinner ready to cook after a couple of missteps there that wasted some time. This ain't the cooking channel, so I won't go into that! Anyway I got the food in the oven, then went back out to get the new chain on. Since I had to changed sprockets, I couldn't use the old chain to pull the new one through, so I had to thread it though, but the timing case was off so it wasn't bad. I got it through and put the master link in and thought, Damn, that looks awfully loose. Aw, shite, I forgot that the chain was 2 links too long because the outfit I orders the chain from didn't have the 102 link job, so I had to order a 104. Dinner as ready and my wife was home and wanted her parking spot in the garage, so I had to move the bike over into it's normal parking spot. I pulled the master link out and the chain fell off the sprocket as she was driving up, but I had to pull the chain off to remove a couple of links. I quit for the night.
Started out earlier today and got the links removed and the chain installed. I got real lucky, I didn't have to adjust the chain at all, it was perfect where it was. No doubt, I'll have to do it soon as the chain beds in. Anyway, time to reseal the timing cover. The cover had a gasket on it and I managed to remove it intact. I got out my sealer stuff and discovered that it as almost empty and drying out, but to keep from having to go out again I gave the stuff a shot and it went on OK and I got the cover back on. It seems to have sealed the cover up. I stuck the filter back in and put the plugs back on the bottom of the case and filled it with oil. It looked like I overfilled it, but I started it and as it run the level came down as the oil pumped into all the little spots it needs to go. Then the filter cover started leaking. I took the cover and found the O-ring that seals the cover got a bit shaved off it during reinstallation and was now leaking. I put the tiny bit of sealer on it to see if it would hold and it apparently has. I took the bike out for a test ride, then road over to my nearest RE dealer and was going to by some o-rings, only to discover that I had forgotten my wallet! But I checked it for leaks and it wasn't so it didn't matter that much anyway.
The test ride was through my closest canyon and the gearing was alright. It seemed to be a bit more sedate, but I got more speed before I shifted. The seat buzz point went up from 62MPH to about 66MPH which is a bit faster that I normally, so it will be somewhat beneficial. I did find myself staying in fourth gear on the streets in the 40-50 range instead of shifting. When I did realize what gear I as in I did shift. The gearing should benefit mileage as song as you keep short shifting. The acceleration doesn't really appear to be affected to any great degree. I think I'm gonna like the gearing.
So when I got home I had found that the seat I had ordered from CMW on the off chance that it might fit. So I stuck it on and it fit fairly well. I need to bend the tab that holds the front down a bit to make it a bit snugger, but basically it fits the bike! But it doesn't fit me very well. I'm going to have to rework the foam a bit, but just a minor deal.
Here are some pictures I took of the old OEM chain, good for 6500 miles, vs a real chain that should be good for 30,000 plus.
Note that the side plates are much thicker on the Tsubaki; .085 vs .062 on the OEM. The OEM chain also has split pin bushings which are guaranteed not to last very long, See the bend in the worn out OEM? That's shot bushings and pins. The Tsubaki has solid bushings that are a heavier material than the OEM. $60 for an OEM vs 110 for a Tsubaki...You do the math.
