I decided to change my oil and filter today even though the manual says it isn't needed for another 1300 miles.
I figured that after my 400+ mile freeway speed trip it might be a good idea to change it.
Both magnets (one on the drain plug and one on the strainer cap) had a light accumulation of steel filings on them so I think the break in period is about over.
I tried a different method of getting the "extra" oil out of the side cases by draining the oil with the bike on the center stand and then dropping it off of the center stand and tipping the bike both right and left, holding it in both positions for awhile.
This did get some extra oil out of the crankcase. It took 1.85 quarts to refill it.
Although I'm sure the filter is working like it should I noticed that the drained oil had a metallic look to it when the sun was shining on it so I feel better knowing that those fine metal flakes aren't in there lubricating my rolling element bearings.
