I finally got the J-3 Cubby nee Beast back together enough to ride it again! After being rear ended a few weeks ago, then pitching it off the side of the road, I was needing a few bits. It's amazing how slow parts are forthcoming nowadays! I still need the stock bars, front fender, headllight surround for the Tribar, an EFI muffler, right switch box, and tail light.
I got enough pieces though to be able to ride it again, after market bars were the most important. I used the original headlight, repainted the casquette and hand hold bar and straightened out the footpegs and other bits.
Anyway I took it out for a checkride and all went well for about 5 miles, then it started cutting out severely, the popping and banging, then quit. It finally restarted, sounding pretty good as i head home, for a mile or so, then started crapping out again. I nrsed it on home and as I was pulling into the garage, it quit again. I went into the house for a drink and the opportunity to mull over what was wrong with it, as I had done some extracurricular work on it and played with several connections. I was getting ready to pull some side panels, when for whatever reason that escapes me...as most things are wont to do nowadays, I grabbed the spark plug lead and it was loose--really loose. It was just bouncing up and down on the plug. Stuck it back on and got in a successful twenty mile ride through the twisties. Feels so good!
It does vibrate through the handlebars a bit more than with the stock ones. I'll havta figure out how to cure that.
But there is that BSA Club ride Sunday.!
