I decided to look into the electrical situation under the left sidecover on my G5.
I haven't had a problem yet but I know the harness is a weakness on the RE's.
As some of you know, there are a bunch of wires connected to the three fuse holders and there are also some sharp metal edges both on the edges of the cover and on the part the lock engages.
I was disappointed when I found that RE seems to think that black plastic electrical tape is all that's needed to protect the wiring. Knowing that a dull knife will cut right thru plastic tape like that I got to thinking.
I have a bunch of 1/4" and 3/8" vinyl tubing so by slitting up one side of it I made some covers for the wiring.
After opening up the slit and pushing the wiring inside it closed back up to its tubular shape but just to make sure I taped the slit with some of the Indian harness covering material (black plastic electrical tape).
I also noticed that the Hot lead (+) that runs from the battery to the starter solenoid, where it comes out from under the side cover was trying to embed its insulation on the sharp metal edge. Talk about a potential problem! If that cut thru and the lock grounded the cover all sorts of sparks could fly!
A short length of the larger vinyl tubing was installed to cover the wiring at that location.
Some lengths of shrink tubing that are slit to allow installation or some of those flexable plastic harness covers from the local auto parts store would have worked in place of the tubing but as I mentioned, I already had it on hand.
Someday before too long I'll pull the gas tank and add some more tubing to the areas where the harness contacts solid sharp metal edges.
