Tri - I saw that one but its cast iron (ugly) and requires welding (dont want a permanent solution in case it sucks.
I have a custom snuff r not in the works...
I just need to weld that center washer to the screw and pop a hole in the pipe. A lock washer and thumb screw hold it together. As long as I turn it clockwise only, it should stay tight, we'll see. You can just see I notched the end of the screw so I had some way to tighten everything, and it lets me know where the flapper is oriented. My plan is to put it just after the header pipe. Hopefully that works, if it doesnt, I'll put it towards the end, which I guess is the more customary position.
This is the $25 emgo shorty pipe I'm using (Pipe # 4 for me!):
It has internal baffling, but basically is a straight open 1" pipe though the center, so I'm guessing it will be quite loud, but I'm hoping it has some of the flavor of the EFI pipe, just louder (my goal). The muffled section is about a foot long. One nice thing about this pipe is that it has a removable baffle, so with that functionality and the snuffrnot it should be fun to tune for back pressure (power) and sound.
I've attached three washers here, but my guess is that I may only need the one center one. When the washers are in the pipe at 90deg, there is about 1/4" clearance around the edges for exhausts gases to pass by.
