Sweet Jesus, IT WORKED! Hallelujah! Begone, rattling noise! Or, should I say, begone MAIN rattling
noise. Without that racket, that is, I now perceive something smaller. But I already have three suspects.
Look:
1) the front caliper brake hose clip. It constantly comes undone. And the rubber piece touces the mudguard rim!
2) the headlight. I switched the original bulb with a Ballack yellow anti-fog one. Where I live is often foggy, and
forget about the retro look (although, well...) - it works. But there is probably some casquette re-arranging to be done.
Because, as you can see, it doesn't close perfectly.
3) the possibile culprit: that bunch of really tough, springy cables in the middle, held by the plastic band - I guess they have
something to do with ABS, but I could be wrong. They vibrate against the tank rim, and I believe the tank resonates. If I, while
running, put a hand on the tank, the rattling subsides, and almost vanishes. As you can see, they are even slightly
dented at the contact point!
I'm optimistic. Without the main rattle, the bike is another bike. And I love her even more.
