My bullet started to make a squeaky noise from the front when i am riding and i see that its coming from front wheel. When i keep the wheel on stand and rotate it, the wheel comes to a halt at a point as if the breaks are stopping it. Not sure whether the brake pads need to be serviced? Or the caliper needs to be serviced/greased. Or anything else? Its only been 3500 miles. I appreciate any suggestions.
Also, do you suggest if Permatex 80653 Silicone Extreme Brake Parts Lubricant is the right choice for caliper servicing?
