Author Topic: INT650 S&S mods  (Read 6662 times)
jweber1957
on: December 04, 2019, 06:34:06 am
Hello all!
If I mount the S&S silencers, is there a requirement to re-map the EFI and open up the intake?
-John
darmahman
  • I've lived in Colorado for the past 43 years.
Reply #1 on: December 04, 2019, 04:47:30 pm
No none needed but I did do the S+S air filter they sell also.
« Last Edit: December 04, 2019, 04:50:52 pm by darmahman »
Scram 411, Moto Guzzi V85, BMW R100GS, Road King, BMW R1200C , Suzuki DRZ-400E
Tuchulcha
Reply #2 on: December 04, 2019, 11:47:55 pm
I also did the S&S pipes and the DNA hi-flow air filter, did not remap anything and everything runs great.  I've watched a ton a videos about that and none have suggested remapping or Dyno.
BRG-BIRD
Reply #3 on: December 05, 2019, 04:09:05 am
S&S exhaust here too with no other changes and the 650 fuels perfect.
Mav
  • Nottingham UK
Reply #4 on: December 05, 2019, 09:23:19 am
There is an ECU setting procedure. See Here:
https://youtu.be/XjHjpuSjDvM
2023 Triumph Tiger 900 GT Pro
2019 Royal Enfield Interceptor
hadujorganic
  • Bethesda, MD, USA
Reply #5 on: December 05, 2019, 03:44:47 pm
Stuart is basically saying let the bike idle for 10 or 12 minutes immediately after fitting the performance filter to let the bike recalculate the fuel/air mixture. I don't doubt his advice but for all the aftermarket pipes that have been installed on 650s, this is the first I've heard of the procedure.
Bethesda, MD  "Home Of Its Residents"
2019 Royal Enfield Interceptor 650
2021 SYM Fiddle III 200i
2019 Trek Checkpoint
1998 Plymouth Grand Voyager
mwmosser
  • Illegitimi non carborundum
  • Austin, TX, USA
Reply #6 on: December 05, 2019, 08:30:03 pm
The ECU will recalibrate probably quicker than 10-12 minutes, most likely within the first few minutes. Stuart's point is that you want to avoid taxing the ECU with wide range of throttle inputs, thus his recommendation to let it sit at idle. I haven't swapped out my exhaust yet, but when I do, I'll do that.
2019 Interceptor 650 Mark Three
beagle
  • Australia
Reply #7 on: December 08, 2019, 08:29:01 pm
Has anyone fitted the cams, air filter and pipes combo that are available for the 650.
Drink now....avoid the Xmas rush.
greetings from Brisbane, Australia
jimku
  • Nampa, Idaho USA
Reply #8 on: December 08, 2019, 11:24:15 pm
I put a set of AEW silencers on my Interceptor.  Looked at the S&S silencers and the price killed that idea as well as the fact that you cannot remove the ends of the S&S silencers and remove the packing.  In my opinion the AEW silencers are just as good as the S&S, same design, any difference is minimal other than the end caps.  I removed the baffles and all of the fiberglass packing from my AEW silencers and the sound is awesome.  Loud, but not too loud, deep and throaty, and with a bark that will get attention.
https://www.sparezo.com/royal-enfield-interceptor-650cc-exhaust-muffler-silencer-with-db-killer?search=interceptor%20exhaust
« Last Edit: December 08, 2019, 11:33:09 pm by jimku »
2019 Interceptor.
I hope my tubeless wheels make you cringe. 8) https://www.dropbox.com/s/zobmpjq2gqtvypj/RE%20TIRE%20AND%20WHEEL.JPG?dl=0
Sometimes you're the windshield, sometimes you're the bug.
https://youtu.be/GG5ghP8XLW8
darmahman
Reply #9 on: December 09, 2019, 12:39:47 am
You are quite incorrect what you stated below. The reason the S&S exhaust is pricy is because there is no packing!  It is made of pure stainless steel baffles. Never wears out. Always sounds the same. The street version does have a very small cat in it.
 Very high quality. That is why there is no end cap... but there is a baffle that is removable.
« Last Edit: December 09, 2019, 12:51:39 am by darmahman »
jimku
  • Nampa, Idaho USA
Reply #10 on: December 09, 2019, 02:05:08 am
Well, sorry that I was not correct.  All I know is that I listened to sound clips of the S&S and AEW silencers and couldn't tell any difference.  When I removed the packing from my AEW silencers there is definitely a difference ... noticeably more roar and bark.  Can't do that with the S&S.  My AEW silencers can't wear out now either.  :)  I can still put the db killer baffles in to quiet them down.
« Last Edit: December 09, 2019, 02:07:21 am by jimku »
2019 Interceptor.
darmahman
Reply #11 on: December 09, 2019, 03:45:10 pm
Of course they don't "wear out" but the packing will. Maybe that is what you want.
mwmosser
  • Austin, TX, USA
Reply #12 on: December 09, 2019, 05:09:16 pm
Never heard of pulling out the packing on an exhaust, but it makes sense, I guess. I know it changes the sound, but does it change the airflow/back pressure at all?
olhogrider
  • Classic 350 Desert Sand
  • Blue Ridge Mountains of NC
Reply #13 on: December 09, 2019, 09:39:18 pm
The problem is the sound clips. They sound the same if it is an open pipe with no mufflers or completely stock. It's like trying to tell which cheese tastes best by watching a video.
Dr Mayhem
Reply #14 on: December 09, 2019, 09:41:18 pm
LoL  ;D  funny!!
Guy
19 Conti GT in Dr Mayhem paint 08/24/2019
06 HD Street Bob
04 Buell XB12S Lightning
