Royal Enfield Motorcycles => Vintage Royal Enfield => Topic started by: High On Octane on May 19, 2014, 02:20:05 pm
Hey guys, I got stranded in a canyon yesterday with a stretched throttle cable and I'm taking off work today to get a replacement so I can go get it fixed and get the Blackhawk back home. I originally used a bicycle cable that I soldered together and that worked for the last year, but when I tried making a new cable again yesterday out of despair, for what ever reason I could not get the nipple to solder onto the cable. So now I am looking for an actual replacement cable, something popular like a Suduco or Barnetts, that I can pick up at the local shop TODAY. I have 2 choices in shops: One shop that sells everything imaginable for every Jap bike imaginable and a small handful of Triumph parts. OR there is another shop that specializes in Unit Triumph bike repairs that sells SOME cables and may have a cable that will work.
What I need from you guys is a part number/s of a cable/s that are for a fact known to work with a standard throttle grip and a Amal 930 concentric carb, total length of about 3' (never actually measured it). Thanks in advance!
Scottie J
Call them and ask if they have a universal one that you can solder the ends on. I think a dirt bike shop would still have them. ERC
Sudco has one.
Enfield Throttle Cable, Part # 021-947 is what works on all Bullets.
Should work on your single-carb twin.
It's a Motion Pro cable, really good quality. We use it on the Fireballs.
Sudco has one.
I have bought Motion Pro cables from Performance Cycle before, here's to hoping they it in stock. Thanks Tom and Roger!
Scottie J
http://www.flandersco.com/FlanCableSearch.html
To permanently eliminate cable breakage at the throttle end there is a simple mod I do the cable groove of the twist grip.
Assuming one has the throttle housing apart and the twist grip in hand, take a look at the entire cable groove and notice a sharp turn in the groove where it transitions from straight to circumferential just up from the recess where the cable lug seats. That transition focuses all the flex in one spot.
Using a swiss file, blend that sharp corner to a progressive radius and the problem is permanently solved.
Thanks for the tip Ice. I changed grips this past week and noticed my throttle cable was beginning to lose some strands due to that exact issue you describe. And I snapped the end off a year ago.
Thanks for the heads up. I ended getting a Barnett cable for a Triumph T6R to work.
