The file I have attached gives the correct engine and gearbox numbers, sadly not frame but can help in identifying if at least the engine is correct and not been changed at some point.
Does look like a Chief but don't think it is, the Chief had wider forks and fatter wheels, I think you are right in that it is dressed up Trailblazer.
