Hi Grumbern, thank you for your reply. It is just what I was hoping for, the actual experience and advise of a Scissor Clutch equipped bike owner!
I will pass it on to the seller of the bike, who is intent on setting up the bike properly before the sale.
He is presently awaiting the arrival of a set of lighter springs which Allen from H has sent.
I believe the clutch was purchased from H and Allen is confirming that heavy springs were included to prevent slippage, in the quote from corrospondence shared with me below:
"The Scissor clutches are not the lightest so it will depend on what you are comparing it to.
I would ensure the 3 distance tubes are the correct length in case they have been shortened. They should be 1.17” long.
The 6 springs used on this clutch are the strong springs as standard. We do a lighter spring but you may experience clutch slip. You could try 3 of each.
https://accessories.hitchcocksmotorcycles.com/18077 You could also try a washer under the 3 distance tubes to relieve the pressure on the springs.
Ensure cable routing is good with no snags and look at a handlebar clutch lever with a small distance between the pivot bolt and the nipple. If you can find something with 1” or 7/8” centre distance."
If anyone else has experience or advice on the Scissor Clutch please reply. I am hoping this thread will give guidance for others in the future, as well as for myself today.
I am counting Grumbern as one who says Scissor Clutches work well once properly sorted!
I am making note of your advise on the clutch disc's, in case the spring swap and / or washer addition, maybe a lever swap fail.
I hear varying advise on the conversion to the rod type as you mentioned, and have been told the gear box case itself had to be changed, as well as internal parts... if it ever did come to a clutch conversion, it would be nice to at least retain the original case.
Ed
