I decided to try some inexpensive racks from India. Quality is as expected I suppose. Fit is decent, but to fit right, you need to source your own bolts, spacers, washers, and the like. Required some touch up paint in places as well as cleaning up some sharp weld spattering in a few spots.
Based on listing photos, I thought the bottom of the rack was welded on, but it’s a bolt on affair (I think I need to seal the joint to prevent water ingress/rust). Not a preferred construction method, but functional overall. Pretty solid once mounted, and for the relatively low price, it should do to strap some bags on it. I kinda like the looks of them too.
