"Before finding this site, I watched a Bullet oil change video on Youtube. They drained the oil and then ran the engine to blow the remaining oil dregs out the bottom. It was mortifying. I thought-- there's gotta be better information than this. The upside of getting rid of every last oil drop is offset by the downside of running an oil starved engine. By about 267 times."Ditto in spades!! NEVER run something dry deliberately, especially plain bearings. "Getting every last drop" out of THIS motor is plain foolishness.
Here's what I do: Dump out whatever you get from the oil tank, clean both the front & rear swarf screens with an eye looking out for potential trouble, pre-saturate a new filter and install it, then top off the oil tank. Pull the Quill bolt and peer at the seal. Hold in the compression release & boot thru maybe 25-40 times and you'll finally get oil up to the quill bolt pressure port and BAM it's done. Recheck the level after a minute or so of idling to see if the oil tank is between the marks. If there was oil to the top end before, there'll still be oil to it when you are done. Oil to the
crank is the thing - everything else accesses under external covers and is easily replaced in the unlikely event it failed exactly at the time you changed the oil...
Besides, the timing cover holds about 2 cups all by itself, so unless you remove the timing cover, all that "icky" old oil is still in there mixing with the fresh stuff. At oil drain intervals of 1,500 - 2,500 miles, plus leakage replenishment, I'm not seeing a real problem.
