That's how it used to be with Amals, or still is if you're running one.
OK, stud length: you'll need the depth of the M6 threaded holes in the inlet port (I can probably measure that myself) + thickness of carb flange + 8mm for the thickness of the tufnol (1 of those will be plenty), plus the thickness/depth of your favourite M6 nuts + about another 4mm to allow for a gasket, two washers and a couple of threads proud at the end, I can probably find you some studs too. There are titanium ones out there...
What size holes does the rusky carb have in the flange, and what are its centres? 60mm, same as the Electra-X/AVL Classic head would be nice.... I assume you want a 32mm center hole to match the Fireball inlet tract. Also what's the top to bottom and side to side width of the carb flange?
