Well... I guess I win the "Idiot" contest! As I am looking at the charging issue, I again, ensured all wiring is correct and has good continuity, re-cleaned control box contacts, re-polarized the dynamo and also checked the dynamo output. Everything was as it should be. No problems found. I start the bike up and am watching the ammeter swing to the negative every time I rev it up and it hits me.... Duh...... the charging system is working perfectly. It is a positive ground system. If it was discharging the ammeter would swing positive. Just the opposite of how things are done here in the US. I am a big dummy! I am so used to the negative ground (earth) systems we use here that I forgot I was working with a positive ground. I should know better whereas my last two Triumph choppers and the Triumph pre-unit bobber my son and I recently built were also positive grounds. It is not like I haven't worked on these systems before. Oh well... there is a silver lining. As I was going through all my system checks, I did find a problem with the screw that holds the two wires into the dynamo. It seems some of the Bakelite material (I think that is what it is) on the end of the dynamo that screw goes into had chipped and the screw was therefore not long enough to securely hold the wires in place. I sourced a tad longer screw and remedied that little problem.
Now on to the oil leak. As I was going through the few spares I received with the bike, I was pleased to see that there was a brand-new timing chest cover gasket. Perfect. That timing cover will be removed next to see if the oil seal is properly installed. I also noticed after running the bike a bit, the gasket on the triangular plate on the magdyno unit was wet. I found the screws were not tight. I tightened the three screws I could access. The fourth screw will be accessible after I remove the magdyno unit from the engine. I am thinking a little blue loctite might be in order for these screws. more to come.....
