I've had a lot of bikes and have never seen one that didn't have a speedometer that was not a little bit optimistic .
So
I got my GPS stuck on my Meteor and off I went for a ride.
The Meteor speedometer needed to get up to 53mph for the GPS to read 50mph.
Well
Knowing that "speedometer error" is a linear equation , its easy to see we are dealing with a 6% error.
How to fix it is next ?
The sure way is to use a 6% larger dia. tire on the wheel that has the speedometer pick-up.
well
That's where the problem comes from : Both wheels have Speedometer pick-up ! ? !!
Some bikes have the speedometer pick-up in the transmission , is the Meteor one of them ?
If so then a simple change of sprockets fixes it ?
What do you feller think ?
