OK, but grease doesn't really flow too well. If the box is full of grease/oil amalgam, maybe, but again, this bushing is directly under the two Indian-rubber seals that would be much more likely to leak, so any leakage will be seen there. In any event, you'll still need to pull the primary to get to it to accurately diagnose the source.
The question I have is, is this a livable leak? Gear oil is cheap, a bit of cardboard/newspaper/cat litter and a quart of 85W/140 will last a long time at a tablespoon every 1/2 hour or so while running. Replenishing "00" with gear oil is easy, harmless, and allows you to use the level check plugs. Pulling the primary covers is almost a "routing maintenance" event on these machines, so you'll need the pullers, seals & gaskets soon enough anyway. But if the leak is livable, "doing nothing" but topping up the gearbox is OK too. There are no points awarded either way.
Bravo MrUnderhill1975a. Another quip is "It's not leaking, it's exuding class...". In my Husqvarna days the fork seals were notorious leakers. We told the Yamaha riders that thet were designed that way to prevent stanchion galling..
