Hi,
In the last week, my engine management warning light on the RH guage, has failed to go out intermittently after engine start up. The first time, I thought I may not have given the fuel pump priming long enough. I turned it off and on again and it was fine. The following day, I rode it again and it was fine. Yesterday, the warning light stayed on again. This time it ran rough on its centrestand, tickover slowed and then died. I gave it another go, the light stayed on. 3rd attempt it was fine. Rode it for a few careful miles and it ran as per usual, without the warning light. Tonight, in my garage, it happened again and stalled. I tried it a couple more times, it started and ran ok, but the light stayed on.
I'm wondering if anything I've done could have caused this:
1. After a careful running in, the bike is now on 2100 miles. An aftermarket exhaust added 600 miles ago (hitchcocks gold star style). No tuner, stock air filter. It has run fine since, until now. I checked the (stock) spark plug tonight, it looks fine. The gap was 0.8, so I set it to 0.75, but the light remains on.
2. I had just adjusted my handle bars, rotating them toward me and adjusted the position of the brake lever. I've checked the clutch switch connectors on the bars. It was a bit loose, so I pushed it in, but no improvement. The cables and wires going to the binnacle aren't under tension. Nothing looks pinched.
3. A week or so ago, I went round the engine mounting bolts and the O2 sensor to check for tightness. All were fine, apart from the front bottom frame mounts, which felt a bit off fully tight and I tightened them up.
4. At the same time, I checked my air filter for any oil from the crank breather. There was a small residue, which I wiped off and put back together. The oil level reading in the sightglass is all over the place. When I did the oil change I filled it to mid way between the markers by the sight glass, ran it for a few minutes and it returned to the same level.. Since then, it is usually between the markers, but sometimes reads empty (when it has been on the sidestand), sometimes overfull. But it isn't blowing anything significant into the air box. About 500 miles since last oil change and less than half a thimbleful in the air box. I had last checked the air box about 1,000 miles ago.
5. The only other things I've done: I have a hitchcocks headlamp peak, which I put on about 1800 miles ago and their small screen. Oh, and I've cleaned / lubed the chain! The dealer did the first service.
Before I ring the dealer and call on the warranty, does anything I've done prompt any thoughts or suggestions?
Many thanks,
Martin
