General Discussion => Sidecar Talk => Topic started by: AwL on July 24, 2012, 02:26:05 am
What tire pressure is recommended for bike -2009 G5 - with sidecar attached? Thanks, Al
30 rear, 25 front, 20 side.
In my experience with many different types of hacks (Urals, Yamaha 650/Velorex, old '75 Goldwing/Velorex, HD Nightster/Cozy) - this is a general rule for me:
Max (or near) pressure on the tires - all three.
And that is based on the manufacturer's max pressure on the sidewall.
The sidecar is a load on the bike - and as with any large load, to increase tire pressure is a good thing.
And that can be very different - my Cozy pressure is 33 psi - with the Metzler - but *not* so with the stock Indian tire that came with it - and now serves as the spare. (see http://mysite.verizon.net/respud62/id10.html)
Well, it has to be mentioned that bike and riders differ as well as the toe and lean of the rig and tire type. All affect the ride of the hack. I have found the above pressures to work on my rig in that the machine turns well and tracks properly down the road with those pressures.
I usually keep the rear pretty hard as it is that tire that scrubs the most in turns etc. I also found the car to be too bouncy and unpleasant at 30 lbs.
Increased tire pressure to 30 front/rear, and 25 sidecar. Rode better with less wobble prior to installation of steering damper.
