I am in Thailand and the only new choice is a heavy, locally made, fibreglass hack that is fairly fugly. I was lucky to find a Cozy that someone imported from India, so bought it and fixed it up to my liking. Modified the mount, TIG welded over the crappy welds, new swingarm, disc brake, YSS steering damper, 18" Enfield alloy rim on stainless spokes with tubeless conversion, Brooklands screen, proper paint that does not fall off, up-rated springs on the YSS shocks, front springs, Sunbrella tonneau, modified seat, LED Harley headlight where Cozy has a blanking plug, + another as an auxiliary spotlight, the list goes on and on.......... A TEC pipe made mounting easier as nothing on the L side of the bike (we drive on the R). Remove the now, not required centre stand, for a mount point
It could come off now to ride solo but oversprung, and a bit of a hassle to re&re each ride. Buy a solo bike
Besides being a bit terrifying to ride for the non-sidecarist, it became pretty clear that the brakes and steering could do with a bit of improvement. I fitted a 4 piston, axial mount Brembo calliper and Brembo radial master cylinder to the bike front which made a huge difference. Braking is still a bit odd compared to a solo bike so I need to relearn the lots of front brake technique and use both front and back together. Pic is pre brake upgrade, but see
https://www.facebook.com/Royal-Enfield-brake-upgrade-112546374592213Steering is a bit heavy and reduced trail is the easiest fix if one is to retain the stock hydraulic forks. Once you reduce the trail you will not want to ride the bike solo. It is OK without the yoke mod, and properly aligned, I have run it to 120 kph without issues other than the heavy steering.
Next on my list of things to design and make, is a set of alloy yokes to reduce trail, and a bit wider to simplify fitting the Brembo calliper. This will be a one time effort so if anyone wants in on it let me know.
The mounts still are a bit too agricultural looking for my liking, and will probably tidy them up after the yoke project
