Author Topic: Interceptor 650 ABS Error code  (Read 5882 times)
Roshiba777
on: July 07, 2021, 02:09:00 pm
Hello Everyone,
      My 2019 make interceptor 650 is facing strange issue with the ABS system  while riding the bike the ABS light start to glow in meter console and goes away after sometime then again comes back.
Today gone to Royal Enfield Service station they checked the ABS system with the company engine management system DOL tool its showing error code C1059 Which is for ABS voltage high and failure type UZ its been shown in the error code history and the company people deleted then error code from history but again after 5-6 kms of ride its again showing the same symptoms and DTC Code C1059  ABS Volatage high and failure type UZ.
What should have caused it or the ABS is giving up please help
Royal Enfield CI 500 (2000)
Royal Enfield STD UCE 500 (2010)
Royal Enfield Classic 500 (2011)
Royal Enfield Classic Chrome 500 (2011)
Yamaha RD350 (1988)
Royal Enfield Interceptor 650 (2019)
supercub
Reply #1 on: July 07, 2021, 04:42:39 pm
Check your battery voltage while the ignition is off and then when it's running. If the voltage is excessively high, it could be your charging system.
2021 Conti GT650 "Ice Queen"
1965 Honda CB160
2016 Honda CB500
2019 Suzuki TU250
Other project bikes
6504me
  • SW USA
Reply #2 on: July 07, 2021, 09:51:01 pm
Check that the  front & rear ABS sensors have not been disturbed.
lucky phil
Reply #3 on: July 09, 2021, 01:16:00 am
Hello Everyone,
Possible causes
C1095 Possible Causes What does this mean?
Low Brake Fluid
Faulty ABS Hydraulic Pump Motor
ABS Hydraulic Pump Motor harness is open or shorted
ABS Hydraulic Pump Motor circuit poor electrical connection
Ciao
Ducati1198
Guzzi V11 Sport/Daytona
GSXR1000
Ducati 1000DS Supersport
RE Interceptor
Roshiba777
Reply #4 on: July 09, 2021, 03:03:52 am
Today checked it again at service Centre and after a lot of finding they say that the RR unit is faulty that has caused ABS High Voltage. Now waiting for the replacement RR Unit
Yamaha RD350 (1988)
lucky phil
Reply #5 on: July 09, 2021, 07:18:00 am
Sorry I had C1095 instead of C1059. C1059 is Voltage too high and yes a new RR should be the fix.
Ciao
Ducati1198
GSXR1000
RE Interceptor
Roshiba777
Reply #6 on: July 21, 2021, 11:06:40 am
Ciao
RE is replacing the RR under warranty should there be any problem with the Stator assembly
Yamaha RD350 (1988)
Roshiba777
Reply #7 on: July 22, 2021, 09:03:32 am
Is it necessary to change the Stator assembly along with the RR unit
Yamaha RD350 (1988)
lucky phil
Reply #8 on: July 22, 2021, 09:30:49 am
No
Ciao
Ducati1198
GSXR1000
RE Interceptor
Roshiba777
Yamaha RD350 (1988)
alejojara
Reply #10 on: October 18, 2021, 09:41:21 pm
Hi, I have an interceptor 650 with the same problem, first time in service they told me that is humidity in the sensor or dust; they clean it but the abs and check engine light lighted up again. Any luck changing the RR unit? because my problem appears when I'm going really slow due to traffic jams, I donĀ“t think that is overheating, maybe something about the electrical parts when the engine is running slow or idle.
sepelaezgi
Reply #11 on: November 16, 2022, 09:18:33 pm
Hello!
I have the same problem after 3 years of having my motorcycle. I no longer have a warranty and I would like to know how those who have already had this problem solved it
NVDucati
  • USA 2020 INT
Reply #12 on: November 16, 2022, 09:30:35 pm
Hello!
Even out of warranty ... you could ask your dealer if they know what the problem is ... and how much to fix it ...
If they don't know, ask them to find out so that then you can continue discussions.
Sometimes it makes sense to pay a company for a repair. But it is never a good idea to turn over anything for a specific repair if they don't know how to fix it.
Member: AMA
Current Rides: '14 DL1000 ADV, '06 SV650N, '93 900CBRR, '74 Ducati 750GT, '14 Honda CB1000-R
twocoolgliders
  • Cookie
Reply #13 on: November 17, 2022, 12:08:48 am
I had similar problem.
It was a bad regulator /rectifier
when the voltage goes whacky, it can trip a sensor and idiot light.
By a cheap digital volt meter gauge, and connect to battery while riding see if the voltage is steady at 14+volts  of if it spikes up to 16 volts or more at times.
Others on the net have had similar and solved with new RR
Cookie
Hello!
Yinzer
  • Pittsburgh, Pa.
Reply #14 on: November 17, 2022, 04:57:40 am
Buy a cheap digital volt meter gauge, and connect to battery while riding see if the voltage is steady at 14+volts  of if it spikes up to 16 volts or more at times.
This is cheap.
2022 Interceptor MkIII (My bike)
1998 Iron Bullet 500 (Shared bike)
2023 Hunter 350 (Dad's bike)
