On my new LED lights, the white was for a running light. I only needed the red and black for the amber turn signal. You can always go touch them to a 12v battery to confirm. You may also need a new LED flasher due to differences in resistance as compared to stock. They are inexpensive on Amazon, and you can adjust the flash rate on many of the available choices.
