Hi all,
I adjusted my chain slack last night. It was out around 35mm and I brought it back to about 25mm.
I have two concerns here.
First. I realize that 10mm is a good amount of slack to take up, but I feel like I had to turn the adjusters a lot to do it. You can see the difference between where it was and where it ended in the attached picture (hopefully it came through)
Second. After I’ve reached the desired slack, should the adjuster/lock nut be flush with the back of the swing arm? The gap seems strange to me.
Might be a stupid question, but I’m pretty new to the whole thing. Any info would be greatly appreciated.
Thanks!
