Author Topic: Bolts On Cylinder Head Cover  (Read 1293 times)
lucky phil
Reply #15 on: June 18, 2021, 01:08:07 am
Two bolts broke off inside of the head. Amazing. This. sucks.
Here's a tip. 12nm or 9FT/LBS is the torque for a grade 8.8 M6 bolt and you are correct, that is what the manual recommends. However in my experience none of these "specialised" bolts that are unique to a manufacturer such as the rocker cover bolts on the 650 engine are ever grade 8.8 material, more likely a grade 4.6 material which puts the torque at 4.1NM or 3 FT/LBS or 36 inch pounds.
So in my view the manual torque for these bolts is wrong.
Ciao
Ducati1198
Guzzi V11 Sport/Daytona
GSXR1000
Ducati 1000DS Supersport
RE Interceptor
drums4money
Reply #16 on: June 18, 2021, 01:28:24 am
Ciao
Maybe the tech editor omitted the decimal in the factory manual. . . 1.2Nm seems closer to the mark than 12.
hypocrite, four flusher, snake in the grass, just a swindler and wolf in sheep's clothing. . . . liar.
6504me
  • SW USA Int650
Reply #17 on: June 18, 2021, 02:03:16 am
Ciao
Ornamental style bolts rarely approach even grade 4 as they are often cat and not rolled and threaded.
Those who don't know what they don't know... don't know and rarely want to learn.
alex12342
Reply #18 on: June 18, 2021, 04:17:14 am
Western cycle supply should have some in stock, saw them on his website a little while ago
lucky phil
Reply #19 on: June 18, 2021, 04:36:13 am
Won't argue with that.
Ciao
Ducati1198
GSXR1000
RE Interceptor
clachcik
Reply #20 on: June 19, 2021, 04:19:32 am
I'll check it out. They are one time use bolts and this would've been the third time I took the head off to do valve adjustments. The place I bought it from is sending me the parts and I will rip her apart and remove the 3 bolts that are stuck in the head and just hand tighten this time. 9 ftlb seems a little over kill
2003 Kawasaki Ninja 636
2012 Kawasaki Ninja 250
2020 Royal Enfield Continental GT 650
6504me
  • SW USA Int650
Reply #21 on: June 19, 2021, 04:47:28 am
Get all new bolts, all new seals, and a new cam cover gasket.
lucky phil
Reply #22 on: June 19, 2021, 07:52:13 am
For the purposes of clarity and factual information do you have an official reference for this statement or is it an opinion?
Ciao
Ducati1198
GSXR1000
RE Interceptor
Starpeve
  • Starpeve
  • Adelaide, South Aust- Conti GT 650 2019
Reply #23 on: June 19, 2021, 08:41:14 am
Ciao
I don’t believe they are, from other readings on this forum
I’d rather have a bottle in front of me than a frontal lobotomy...
zimmemr
Reply #24 on: June 19, 2021, 12:20:34 pm
I don't believe they are. There is nothing to that effect in the shop manual, they aren't critical fasteners and if they were one time use they'd probably come n the same package as the VC cover gasket.  ;)
6504me
  • SW USA Int650
Reply #25 on: June 19, 2021, 04:04:08 pm
Not single use but this type of shouldered bolt, seal, gasket for cam covers arrangement has been around for a very long time and works fine when new, soft gasket and seals are used then the bolts NEED NOT BE THAT TIGHT to seal.
When squashed and hardened gasket and seals are reused the odds of a broken bolt increase dramatically because you don't FEEL the soft seals and gasket seat (give?).
If I were the OP I'd get all new bolts, seals, and a new gasket then choke way up on the wrench when tightening.
zimmemr
Reply #26 on: June 19, 2021, 04:11:14 pm
+1
Karl Fenn
Reply #27 on: June 19, 2021, 10:52:54 pm
This does appear to be a common problem on the 650, use a left handed drill if that does not work try an extractor in the hole they should take that torque no problem, use a vacume cleaner hose to suck up any swarf whilst drilling, these are badly engineered and the wrong torque provided no more than 5 absolute max. If you have to drill and put helicoil inserts in that won't be good sounds if the internal threads are still OK.
« Last Edit: June 19, 2021, 11:08:51 pm by Karl Fenn »
clachcik
Reply #28 on: June 20, 2021, 02:35:15 am
Thanks for the suggestions, I used a little bit of everything but I went at it for a few hours tonight with extractors drill bits and even dental picks. Finally got the 3 broken nuts out of the threads. From what it looks like, the threads are ok? But I tore up the area around the holes. It looks ugly but I made sure to cover the head very well and had a magnet picking up the broken bits and shavings.
gizzo
  • Live slow, die whenever
Reply #29 on: June 20, 2021, 02:49:10 am
Really great work! Well done.  If you're worried about the ragged edges of the holes, you could knock it smooth with some wet and dry, use kerosene not water to lubricate the paper. But it most likely be fine without bothering.
Take it easy on the new bolts, huh?
simon from south Australia
Continental GT
Pantah
DR250
DRZ400SM
