Rather than replace my fractured terminals with the same design that were likely to fail again in short order, I bought ring lugs and soldered them to the wires with a micro torch. I then made two short brass tubes on my home lathe to bridge the gap from the lugs to the inset battery terminals. Hasn't given any trouble since. The stock brass terminals are so thin and bent so severely, they're begging to break. Horrible design.
