For those of us with fuel injection, starting the bike with the rocker covers off to check the oil flow means removing the tank and rocker covers, but then replacing the tank to hook up the fuel pump and other sensors to start the bike. Unless I'm missing something of course... That's one advantage to running a carbureted bike right there.
I ran my 2012 C5 with the rocker covers off and with the tank hooked up electrically and fuel line, but mounted perpendicular, off to the left side, sitting astraddle a wooden 2x3 that had been baling wired to the bikes frame and had its other end sitting on a sawhorse. Got better visual access to the rockers that way, but still a much bigger pain than running from a gravity fed auxilliary fuel tank hanging over the bike like a IV drip bag, like we can do with carby bikes. I ended up with quite a bit of oil overflowing on the exhaust side and running down the engine. I wonder if that increased oil flow exhaust vs. intake, is related to my lifter noise?, (which I think is coming from the exhaust hydraulic lifter or pushrod)
It occurred to me that I could probably weld a schaeder valve and a fuel line into a sturdy steel bottle, fill it 1/5 full with gasoline, screw on the cap, then pressurize the bottle with air to nominal rail pressure. The relatively large amount of air vs gasoline would keep the pressure reasonably constant over the test period. I've done this trick to get a high pressure water supply, above and beyond what any pump I own can produce. Of course the drawback is working with a pressure vessel full of gasoline hanging next to your head, but it doesn't seem a whole lot worse to me than holding a propane cylinder torch? What do you guys think? That it's amazing I've lived into my 60s?
Or, one could use a gravity fed tank feeding an inline pressure pump. I'd have already rigged this idea up, but the only pumps I have laying around, that are for inline use, and not of in-tank construction, are low pressure leftovers from carby days. If rail pressure isn't reasonably close to spec. the engine might run, but the A/F ratio will be off.
I imagine that most cars and some bikes will have some sensors and safeties that would need to be lied to, but my RE seems relatively free of that complexity.
