Author Topic: Who’s running the 16 tooth sprocket  (Read 5586 times)
Gremlinsteve
on: January 27, 2021, 03:03:43 am
Are you able to reuse the stock chain ?
Starpeve
  • Starpeve
  • Adelaide, South Aust- Conti GT 650 2019
Reply #1 on: January 27, 2021, 03:33:58 am
Yep. Easiest mod you can do!
I’d rather have a bottle in front of me than a frontal lobotomy...
daytonadean
Reply #2 on: January 27, 2021, 07:32:59 pm
https://chainsandsprockets.co.uk/
£9.27 with uk free delivery
biscot
Reply #3 on: January 27, 2021, 09:34:57 pm
May I ask why you are doing this and how it is affecting performance, etc.
Jack Straw
  • LAUGH MORE, LIVE LONGER
  • Prescott, Arizona
Reply #4 on: January 27, 2021, 10:20:47 pm
Going up a tooth on the countershaft sprocket will give you slightly lower rpm at cruising speed.  Typically one tooth will drop the revs around 450 rpm at 60 mph in top gear.  Such "higher gearing" will slightly reduce acceleration but make for  somewhat more tranquil highway cruising and possibly improve MPG under some circumstances.
Going down a tooth, say to a 14 has the opposite effect.
Gremlinsteve
Reply #5 on: January 27, 2021, 10:47:48 pm
I feel it’s a better choice for my current 865 cc build
biscot
Reply #6 on: January 27, 2021, 10:59:17 pm
So I gather the stock sprocket is 15T.
Is that easier/better/cheaper than changing the rear sprocket?
Jack Straw
  • Prescott, Arizona
Reply #7 on: January 28, 2021, 12:19:29 am
Yeah, it's usually less hassle than changing the rear, cheaper too.
Gremlinsteve
Reply #8 on: January 28, 2021, 12:22:08 am
I agree
Plus I already have the front sprocket
Ready to install
Starpeve
  • Starpeve
Reply #9 on: January 28, 2021, 03:02:32 am
Easier and cheaper by far. Contrary to the theoretical reduction in acceleration, I feel that my bike is now quicker due to the  better gearing. Some will argue this point, but most that do haven’t done the swap. BTW my dressed weight is about 80 kg.
To me, the bike feels nicer now in 2nd and 3rd, where acceleration-wise is mainly where it’s needed.
Only a small change, but effective.
And it’s such a cheap and simple thing to do that it’s easily reversed if you don’t like it!
biscot
Reply #10 on: January 28, 2021, 10:42:15 am
Sounds like it’s worth a try, I think I’ll give it a go. Thanks.
RecoilRob
Reply #11 on: June 20, 2021, 03:45:25 am
Just installed the 16T countershaft sprocket and the bike really has taken to it well.   No more trying to shift into '7th' gear and the gearing in 5th now is almost identical to the stock 15T in 6th.   Engine pulls the additional gearing just fine and to my senses it feels happier with the slightly taller gear.   60 mph is showing 3600 revs in 6th and I've always liked tall gearing....because you can always downshift if you want more revs but once you've run out of gears you can't upshift to lower them.   Stock chain fit just fine and the 17T might actually fit...but unless the motor finds more torque I'm going to leave it at 16T...a very happy setup.
Starpeve
  • Starpeve
Reply #12 on: June 20, 2021, 06:31:21 am
Apparently the chain’s too short for 17. Not much room in there either. I copped a lot of grief ( and some support) a while back about my theorising about the taller gearing, before I’d done it. I love it, I think it’s a great improvement, things are better positioned everywhere, hated the short first. 2nd and 3rd are now closer to where I like them, etc. I’m still casually toying with the idea of, come replacement time, going 2 teeth down on the rear. As it is, contrary to speculative opinion, I reckon the bike’s quicker down low because of the better gear placement. What you MAY lose (if at all) on first you gain on 2nd.
Mind you, I’m only 72 kg and don’t take pillions.
Starpeve
  • Starpeve
Reply #13 on: June 20, 2021, 06:33:49 am
Sorry, just realised I’m repeating myself! And that I weighed myself the other day and I’m lighter than I thought! Obviously the beer gut isn’t as heavy as I’d anticipated!
CPJS
Reply #14 on: June 20, 2021, 07:03:24 am
Do you have a part number please.
I tried looking it up without success.
Current bikes.
R E GT650
BMW R1200GS
Honda CRF250L
BSA B25SS
Learn to spell! There's a big difference between knowing your shit and knowing you're shit.
