I decided a new thread made sense on the gas cap topic. Here's the previous discussion;
https://forum.classicmotorworks.com/index.php?topic=29793.0The cap is a 2.5" item from B.A.T. in Florida. It's mounted to their 2.5" aluminum threaded collar which was opened up about 90 thou to slip over the existing filler neck. It's bonded to the filler with JB Weld. The cap body threads onto the collar and will be secured with Loctite blue.
The installation was very straightforward but for the simple lathe work on the collar bore. I had a pal with a machine shop take care of that.
I purchased the parts direct from B.A.T. Cost with shipping was about $160 and my pal did the machine work for a case of Modelo Especial.
The overall look is similar to the stock cap but for sitting a bit proud compared the the locking cap. No more fumbling with the key and the clumsy mechanism. No more concern about the cap falling and bending the key into scrap.
Thanks to Breaker Express for going to B.A.T. and doing the hands-on research. He is exploring an alternate install using a flanged base which will cover the existing recess around the cap.
NV Ducati was responsible for finding the supplier and forwarding the catalog sheets and specifications. Thanks Chuck.
