Glad to hear it was such a simple fix! I've got the horns out of the way (swapped for a smaller louder unit mounted under the tank) so there's lots of space up in the front there. When fitting my TEC system a couple of days ago I noticed how easily the breather hose can slip off. Nothing a carefully placed cable tie can't take care of.
Do let us know what you end up doing in regards to that gasket. I had the same misgivings when fitting the system - not sure why it wasn't a slip & spring joint like all the others? Seems the weak point in the whole line. The 2-1 is so close to being amazing, just a couple of small points let it down:
1. The aforementioned graphite gasket and hose clamp join.
2. The warning in the instructions not to run it without the baffle as this may cause damage (why even provide a removable baffle if it shouldn't be removed???)
3. The muffler-midpipe join has a spring hook on the muffler side, and nothing on the midpipe side. And a note in the instructions that a spring is not required. Why the hook on one side then? And an extra spring in the kit? Surely it would just be prudent to have another spring there just in case?
I haven't been able to do any riding (covid lockdown), just a couple of heat cycles. It seems to be sealing well, and there is a little bit of colour coming into the headers. Time will tell though, once I put some proper miles on it. Fingers crossed I don't have a blown gasket like some others!
curious does anyone know if any of this has been addressed by TEC yet? this post was from almost a year ago. i tried perusing the rest of this thread but didnt really catch any updates that TEC might have done to improve their setup. right now the QA sounds a little erratic with ill fitting parts and inability to remove the baffle without damaging things? seems weird to me.
but i also dont want to get some random no name 2-1 setup from ebay.
the s&s 2-1 looks...bad.
and im reading you probably need to remove the exhaust to access the oil filter? i'm guessing that would be the same issue with the s&s 2-1 as well.
(dont have the bike yet but may be picking it up this weekend...)
