I haven't posted for a while because I've been struggling to find a way to remove the damper tubes from my fork legs. I've finally cracked it!
Having read the various threads on the forum, I expected to encounter some difficulty in removing the damper tubes from the fork legs. I hadn't expected it to be so difficult.
The Royal Enfield workshop manual recommends the use of the special tool 'Fork damper tube holder' Part No: ST26461-2 to prevent the damper tube rotating when the damper tube retaining bolt is unscrewed.
The tool costs about £80 and is basically a T-bar with a square end.
Fred Gassit in his post Reply #61 on: December 10, 2020, 12:35:03 pm stated that the tool had a square end 23mm across. So I made up a tee-bar with a 23mm square end and inserted into the fork tube. I held the tee-bar in a vise and put an Allen key in the tube retaining bolt.
After exerting considerable pressure, the bolt seemed to 'give' and I thought I'd unscrewed the damper tube. I hadn't. The damper tube was still attached to the bolt.
In his post Reply #32 on: April 03, 2021, 06:15:23 pm , NVDucati posted a very useful picture, showing the end of the damper tube which looks very like a standard 12 sided socket. He showed that a piece of 32mm bar fitted very neatly across the socket to hold the damper tube while the retaining bolt is removed.
So I modified my tee-bar and added a 32mm 'paddle' at the end, but I couldn't get it to engage in the socket end of the damper tube.
NevilleG in his post Reply #56 on: December 09, 2020, 11:07:03 am said that he'd used a garden fork handle to stop the damper tube from turning. I didn't have a garden fork handle handy, but I did have an old 35mm wooden curtain pole. I chamfered the end until it was a snug fit in the damper tube end, but it wasn't robust enough to stop the tube from turning when I tried to unscrew the retaining bolt.
NVDucati stated in his thread Reply #58 on: December 09, 2020, 01:34:33 pm that a 30mm nut would fit in the end of the damper tube. An M20 nut is 30mm across flats, so I purchased some M20 nuts and washers and a length of 20mm threaded rod.
I chamfered the end of a 22mm wooden curtain rail and screwed a nut onto it. This allowed me to poke the rod down the fork tube and feel when the nut engaged into the socket on the end of the damper tube.
It didn't.
The nut was still screwed tightly on to the end of the wooden pole and so I was able to use that as a handle to hold the nut while I ground off the corners. I thought I would just have to grind off the tips of the nut to get it to fit. I kept grinding off more and more of the nut and offering up to the damper tube. When I'd ground the corners off to the extend the nut was effectively a twelve sided nut, (a bit like an old threepenny bit) it finally engaged into the socket end of the damper tube.
I locked my 12 sided nut on to the end of the threaded rod with another nut. Then I locked two more pairs of nuts 500 mm along the threaded rod. This allowed me to fit two adjustable wrenches at 180 degrees, effectively forming a tee-handle.
I mounted an mm Allen key into my vise and lowered the fork leg on to it. Then I inserted the 12 sided nut on the end of the threaded bar into the fork tube until it engaged in the damper tube socket. Using the two adjustable wrenches I was at last able to unscrew the damper tube from the retaining bolt.
Job Done!
I had half expected the 12 sided nut to unscrew when I applied force, in which case my next plan was to drill right through the nut and the threaded bar and cut a piece of 6” nail to use as a shear pin. Fortunately that wasn't necessary.
Thanks to NVDucati, Hoiho and gizzo for their invaluable help in getting this sorted.
Next job is to drill out the damper holes.
